jiw700
Scamper340
which end do i shorten
i just had fun with the same thing last year. the inner tube is only around 7" long. youll have to use a sawzall witha long blade and cut the inner tube on one side then with a long screwdriver cheisel apart the rubber from the inner tube. eventually you get the inner one out and then the rubber can come out more easily. when sawing be careful not to cut the outer tube.
If you are shortening the driveshaft because you are swapping out the engine and third member to, lets say a 340/360 and an 8-3/4 you should have a new one built. The driveshafts that came with /6 and 318s with the 7-1/4 rear axle are weak. You can also upsize the yokes to 7290s. They will use a thicker wall tubing and you can drive(read burnout) with confidence.which end do i shorten
