Bring him over to Yakima to make my dogs act right.
No leaky shafts here.Are your shafts leaking on the ends ?
I see!!I think you need to inspect the rockers more carefully.
The holes from the rocker ID to the adjuster screw are there(or should be), but you’ll need to remove the rocker from the shaft to see it.
Re-read post 46.
Yeah, the rocker arm problems on BB Mopar engines multiply as the power level goes up! I learned that the hard way on multiple engines! The original design works for low RPM truck engines. The rotating oil switch in the cam shaft is a clever design but it has an upper limit. The shaft with a bunch of holes that line up with other holes in timed events also is clever, but has limitations. The whole system has to be redesigned as power levels go up.That particular rocker is an intake with a little more offset than the std rockers.
This is what they sold for B1-BS heads.
I’ve seen these start having pushrod oiling problems after a few dyno pulls(roller cam).
The pushrod feed hole is just too far away from the groove.
I found that making a small channel connecting the groove to the feed hole cured the problem.
This particular combo would start to break intake rockers after about 125 passes.
After two rounds of that, an upgrade to T&D’s happened, and that ended the rocker issues for that engine.
