Should I change gears or not?
60Powerwagon
Active Member
Brenham, TX
I have a 3.23 rear. Im going from a 225/70r14 on stock wheels to a 275/60 or 295/50r15 on light weight weld knock offs. I like the way it performs on what I have, but I want a wider tire and I’m adding a suregrip. Will I be ok with what I have or should I go a bit deeper gearing while I’m at it?
The 295 and 225 are basically the same and the 275 are taller 26.6"/26.4"/28" there effect on rear gear .90/.91/.86 x 3.23 = 2.91/2.94/2.78 looks close enough to me. But here's with 3.55, .90/.91/.86 x 3.55 = 3.20/3.23/3.05. So your overall ratio is 2.94 now with the 3.230and 225 the 275 and 3.23 be 2.78 and 3.55 be 3.05 you could go with 3.55 if you choose they be closer but slightly deeper.
Edit* had a mistake fixed now
Don't forget about the possible need to change your speedometer gear if there is any change in gear ratio and/or tire height.
If you can fit 295s, that means you likely have a big-tub car. If an A-body, that means a lightweight Duster/Demon, OR a Barracuda, which, if a fastback, can be a bit of a pig (mine is 3650 with me in it).
The smallest tire that I would consider to put on mine is a 275/50-15 which calculates to 25.83 tall.
The 295/50-15s to 26.6
The 275/60-15s to 28.
your 225/70-14s are 26.4
From the 25.83 to 26.4 is less than 1% change
From 26.4 to 28 is 6% , which you will feel as a modest torque loss at low rpm, or more accurately a weight gain.
a gear change from 3.23 to 3.55 is ~10%, which you will feel as a weight loss.
A gearing change will depend on your engine size, it's state of tune, your stall-rpm, and intended useage; but in your case, the tire-change alone, may not require any . Ima going with RRR/post #2,
cuz 28s sometimes require the rear axle to be moved back......
Oh yeah, if you have a V8, you gotta have a SureGrip.....
If you have a clutch and a 2.66low first gear, then IMO, the lowest number rear gear is a 3.55, for a starter of
3.55 x 2.66=9.44
but if you have a Commando trans(3.09low) then
9.44/3.09= 3.05s are the same starter
But if you have an overdrive A833, which has extremely wide ratios, AND also have an anemic low-compression 318, then you need to look at second gear. Your second gear IMO, should be no less than
1.92x3.55=6.82, With the od box this would be
6.82/1.67= a 4.08 rear gear.
318 cars with regular A833s love 4.30s, with autos, no less than 3.91s, lol. unless a high-stall, then 3.73s
A 360 can go with 10% less so 3.91s to 3.36s which rounds either way to 3.55s or 3.23s, depending on the stall.
Heavier vehicles will want to increase the rear gear, according to the percentage weight-gain. For example, a 10% weight increase would benefit with 10% more gear; ie. 3100 plus 10% is 3410, and from 3.23s to 3.55s is about the same 10%.
These are my opinions based on my experience.
i raced with 3.23s stock stall 26.99 tall tires 340 243@50 cam torker door stop 650 dp with spray trapped in 2nd
i love 3.23s
would have liked to try 4.10s
i liked top end racing to much
5800 in drive was a white knuckle ride
It’s a ‘72 Duster mild 360/727 (stalls about 2600) with 8 3/4 rear. It’s open right now, but I have a sure grip to install which is why I’m asking if I should change while I’m in there.
It is a street car. It has no mini tubs, but I do have the kit to move the springs in when I get the chance.
I have a set of 28x12.50/15 M&H cheater slicks on some weld knock offs. I put them on last night and they clear everything, but have maybe 1/16th of an inch gap between the sidewall and the springs.
I just don’t know which size rear tire to go with.
28x12.5s is tallll for 3.23s
great on the hi-way for cruise rpm if not slicks
2500 rpm is 61 mph plus verter slip
5000 rpm 122 mph plus verter slip
I’m not going to run them because I mainly drive streets. Looking at BFG radial ta’s for front and back.
155/80r15 for front, but torn between 275/60 and 295/50 for the rear
If the diameter of the tire is about the same, then your speed at any given rpm will be the same. If you like the way the car drives now then leave what you have and go.
depends on what you are doing with the car.
