Mopower71
Speed Demon
I've been debating something for a while now, and am still unsure of what to do.
My 72 Demon I have used only as a strip car. It has been sitting in the garage now for about two years.
Should I put a bulb it the one turn signal so it will work again, rehook up the linkage for the wipers, and put it on the road?
I would have to change the spool out of the rear end, and find a decent set of gears for the rear. The 4.10 sure grip I have toasted the bearing on the pinion gear. I have a good 4.56 and 3.23 set I could put in. I would need to find the right gear for the speedometer.
It has no weather stripping in the doors or trunk, and I would have to put a passenger seat in. I'm sure there would be more to do.
What do you think?
What do you think?
