mopar head
DoD nuisance Alien/Squatch extermination team
What year or car did chrysler use a single blade cooling fan? or was this a performance piece?
So, I guess that means you can count to 11 still. >G<
The performance fan is the viscous with it's fluid clutch that will disengauge when cool enough and hook up when hot. The 5 blade off set is weird to look at and tops many electric fans CFM's in the air movement department.
So long as the engine stays cool, your good and thats the bottom line now isn't it. Until you can no longer keep the engine cool, don't worry, but I told you where to go if theres a problem..................viscous fan.
Sorry the joke went over my head, don`t get it? I mistaken your joke as sarcasam. forgive the wack. Thanks Goldduster. It seems to blow better than the off the shelf, high tech, auxiliary fans in parts stores?Yep. Count to 11.... a joke
You have "The good fan set up?" OK, sorry I couldn't help in where it came from. I don't ever remember seeing one like that myself. Why the "Wacked?"
