I was wondering if a 68 Slant 6 can go into a 63 Signet and which oil pan I should get, 63 or 68? I am changing my first /6 and I ordered a long block from Maabco. They advertised pre 67 and post 67 blocks. I ordered a pre 67. I opened the wrap on the block they sent, typed the engine stamp # on Google, and the block came up 68. I called Maabco, and they said the block is fine and that the only difference is the crankshaft. I was wondering if there are any issues with this and if anyone canadvise where to pick up a valve cover, timing cover and oil pan. I am trying to get everything set before I pull the old engine out.
