[WANTED] Slant 6 Manifold Washers
RustyRatRod
I was born on a Monday. Not last Monday.
Georgia
Howdeee. I am looking for slant 6 manifold washers. The traingle "batwings" that hold both manifolds against the head. I will take as few or as many as I can afford. Please either use the REPLY feature, or send me a PM so I will get a message, otherwise I will miss it. Thank you! drive through!
I have an NOS set of hardware. It has all the nuts and washers that hold the intake/exhaust manifold assembly to the head. It does not have any studs, or, the hardware holding the intake to the exhaust though. Mine is the later style thick washers.
Can I tag along here? I need same thing and the fat round spacer washers for the end studs, as well. ONCE RRR has what he needs, (since he posted 1st) I could use a set of the same. plus an extra or 2 for spares in case i drop any during the manifold install ha ha
I "occasionally" see a loose one or maybe 2, floating around one of my tool box drawers, but when I go to actually track them down they "disappear"....
I have some ill send you ill have to find them but I know I have some it may not be a whole set but ill send what I got
