Slant 6 well type choke gasket???
cudaspaz
In a tree near you.
I have a pretty good exhaust leak coming from my well type choke on the 71 swinger/ 198 engine.
It's coming from the choke gasket and sputting pretty loudly now.
I can't locate one in the parts sources I've tried, and was wondering where to find one???
A piece broke off, and it looks to be a checkered outer foil type gasket with a graphite center.
If anyone knows of a (proven) high temp sealer that would work, I'd be willing to try that too I guess.
Thanks.
i think i have the same issue....
any chance you can divulge your gasket source???
PM me if it's classified...
blind :glasses1:
P.S. feels good to be back in the forums.:cheers:
well i think this is kinda odd as i have had to run slants without one while i tracked another down...
so my point is that i dont think there should be a hole...
the gasket is to keep things out...
Just get a Felpro exhaust manifold gasket set. They come with one.
I just made one out of some composite gasket material. Has worked going on 4 years now.
