I think the crank bolt takes either a 1 1/8'' or a 1 1/4'' socket. The timing mark plate should have 'before' or 'after' written on it. Factory initial timing is either 2 1/2* or 5* before TDC. Adjust the valves and put regular gas in it. Then you can play with the timing.
