Slant Rebuild/Build Up
JeffTheMarine
Pacific Northwest
Going to be rebuilding a 225 for my stepside truck adding a MP cam and milling for compression. Curious where the best place to get an all in one kit is for bearings, pistons, rings and gaskets.
Thanks
Jeff
100k + miles ran just fine.(pic)Mancini has some,MP sells alot for/6:toothy5:
Jeff
Engine Performance Warehouse EPW or Performance Automotive Warehouse PAW both are good. I would go Cam delete and buy from Erson ask for a 280/270 its a Great cam. If you want a Hardened gear Oil Pump I am stocking those now $100 for the NEW pump with the Dutra Hardened drive gear. If you decide to get anything from Aussie Speed.com I am now the US dealer for them, including the Hurricane Manifolds.
Hope this helps,
Frank
