Doug.S
1964 Dart More Door
I have a 1964 Dart with a 170 slant 6 and A904 auto. The car currently has a Holley 1920 that has been rebuilt at least one time before I rebuilt it. I can’t get a good idle below 800-900 rpms. I can’t even screw the idle screw down lower as it is not currently touching anything. I believe there are some bent items in the geometry that just are not worth trying to fix.
I digress. So on to the opinion of others question. I have 2 Carter BBS’s sitting on my garage shelf. Let’s assume for arguments sake they are both in the same usable condition. One is numbered to be installed on a 1964 Dart/Valiant with a 225 and auto trans. The other is numbered to be installed on a 1965 Dart/Valiant 170 and auto trans. Again I am putting this on a 1964 170, but I don’t know about the internal differences between the two carbs that may or may not affect the drivability of the car. 225 carb on a 170? Wrong jet size? Etc. Any thoughts would be greatly appreciated. Thank you. Doug
