Sleeving engine block
Steve welder
New York
Im considering having a 4 cylinder flat head block sleeved. Its already 60 over and although there is 80 over pistons available, I dont want to go that big and my block is numbers matching
I read were the very bottom of the block isn't bored to leave a shoulder for the sleeve to hit.
Is that standard procedure? Should a good shop be able to sleeve a block properly?
Has anyone had it done before
They bore a hair under sleeve OD size, then press the sleeve in with a .00x interference fit then trim off the deck on a mill or whatever. Tell them to bore it with the MAIN caps ON and TORQUED! $150 a hole here.
A year ago I had 1 sleeve put in a 4 cylinder Onan diesel engine because water had gotten in only 1 cylinder & pitted it bad. Tha machine shop in Denver put the sleeve in. I just looked at the block & they did not leave a shoulder for the sleeve to bottom on. I hope it holds up OK when I get it back together & running.
i thought every aluminum engine made was sleeved...should work perfect if done correctly.
Usually the block will still need to be bored to the next oversize as the sleeve distorts the adjoining cylinders.
They bore the block , install the sleeve then bore the sleeve to match the other cylinders.
Exactly , however the sleeve being driven in place can distort the adjoining cylinders or cylinder , which would require an overbore of all the cylinders to the next size to correct
That is true, but I'm guessing the OP is wanting to sleeve all 4 cylinders and in his case the distortion wouldn't be an issue.
