[SOLD] slip yoke late model
highflyer
oakley ,cal
This is a slip yoke from a newer 92 vehicle large joint very nice condition..will not fit a727s older models nor will it fit 833,s..for use in the newer trans..35 plus shipping from Antioch cal..pics on request..j
What year and type of vehicle did it come from? 727 and 518 slip yokes are supposedly the same. I might be interested, depending on what it came from. Thanks.
I have one of those yokes - got it from the wrecking yard thinking it would fit my 727. The diameter and spline count is the same but the cross section and design of the splines are different, they are more "square. You could force it in, but it definitely wouldst slide. This would explain why going the other way would have a loose fit...
Whoops sorry for the lack,,,i thot you were making a statement not a question..i got the yoke from a late 90,s van,,, i cant tell you what trans it came from..if one could find some dims from both it would be easy to tell..or what trans with a 5.9 in vans..if a 46 what diameter or 518 what dia.????
I believe it should be the same diameter as a 727, but the pitch of the splines is different. If you can figure out what year the van was that will narrow down what xmsn it is. Good sign that it had a 5.9 in it. Will research tonight to see if I can get the dimensions. If it is a 46 yoke, I will take it. You wouldn't happen to have the cooler lines for that van would you?
Jason
Highflyer, how about you pm a pic of the splines, I may be able to tell if they will work in my 46rh.
