Very true but, those engines as pointed out by badart don't turn very high RPMs. If you are just using the gear drive for a lower RPM street engine for the sound, no big deal but, if you are using it for a high RPM race type engine and think you need it for timing accuracy then you are wasting your money. The valvetrain harmonics on a 59* block with W style heads where the pushrods are working in two different angles are horrendous. It won't support anything over 8000 RPM. This I can attest to from experience. If you add to this a gear drive where there would be no dampening of the crankshaft harmonics it's going to be a valvetrain nightmare. The ideal setup would be a belt drive and/or a 48* lifter block.
