Small Block Crane Ductile Iron Rockers, Grooved Shafts & Spacers- New
I have a new small block Crane ductile iron 1.5 ratio rocker arm package. Comes with the rocker arms, adjusters, rocker arm spacers, a set of stock hold down hardware (not pictured) and a set of hard chromed banana grooved shafts. All parts are new except the hold down hardware. The shafts are heavy duty and thicker than the stock shafts and many replacement aftermarket shafts. As you can see in the third picture, the crane iron rockers have a groove that circulates pressurized oil around the rocker arm to the holes that lubricate the push rod cup and valve tips.
Here is some information on the rocker arms from summit racing.
Brand: Crane Cams
Manufacturer's Part Number: 69770-16
Part Type: Rocker Arms
Product Line: Crane Steel and Ductile Iron Shaft Mount Rocker Arms
Rocker Arm Mounting Style: Shaft
Rocker Arm Ratio: 1.5
Maximum Spring Diameter (in): 1.565 in.
Rocker Arm Style: Non-roller
Shaft Diameter (in): 0.872 in.
Rocker Arm Material: Ductile iron
Rocker Arm Body Style: Standard
Rocker Arm Finish: Natural
Crane uses a high-quality steel alloy or ductile iron that's heat-treated for strength and wear resistance.
I am selling this package for $460 shipped in the lower 48 states.
I also have other small block rocker arms and shafts, new and used for standard small block LA heads (stock heads, Edelbrock, TrickFlow, LAX, …) as well as for W2 and W5. Let me know what you are looking for.
Brand: Crane Cams
PM me with any questions.
