[FOR SALE] Small Block Hydraulic Tappet Camshaft - NHRA Stock Class Grind Used
Rocket
CT
For sale is a used small block Cam Dynamics hydraulic flat tappet camshaft from an NHRA Stock class drag racing car. The Cam Dynamics part number is 10944 and the grind number is 206-2A. The specs are 0.455 lift intake and exhaust with 303 degrees advertised duration and 265 degrees duration at 0.050 lift on both Intake and exhaust. This was used for 1 season and has been wrapped in an oil soaked rag since. It is in very nice used shape. I have the cam card available for degreeing in the camshaft..
Price is $115 shipped to lower 48 states.
This cam will work on any small block LA engine. It has a choppy idle with 265 degrees duration @ 50 thousands inch lift.
I believe these were sometimes referred to as a cheater cam. Rules allowed stock lift but no duration limit if recall correctly of the rules when this was run.
hi, I think you will find, it will idle at 1300 rpm, has very low vaccum. requires total timing at 35 deg, high stall converter, and deep rear gears, in the 4;30 and deeper. it's not very drivable. we used one in our 340, before. they are a racing cam, period!!! they do work good though, when setup with correct converter and rear gear ratio.
