Bighead440
Can you run a truck sump pan in a abody with orginal k frame?
no
What is your pan type and pump etc that you are using for 9:40sAre you sure you really need anything special. How quick are you looking to go and what rpm. Tricks are for rabbits. 9.40’s here at 138 mph with a melling pump and zero tricks shifting at 7000 ever pass.
Just curious.
Just curious.
I was hoping you could be more specific. Rear sump, swinging pickupI tried a Canton oil pan to gain more clearance for an engine diaper and my oil pressure was dropping early in the run so I put the Milidon pan back on and modified my headers for clearance
Etc.How many quarts.
Just seeing what other options I haveWhat is your pan type and pump etc that you are using for 9:40s
Just curious.
