,Slanty 6 bars are used a lot in drag racing. I am building a road race / street 67 notch, planning on 1.03 pst bars. I rewelded the rear torsion bar receptacles in the transmission crossmember. The factory welds are pretty rough. mine was also a replacement crossmember, i removed the old rusty and messed up floor, and welded in a new floor, the.old crossmember ws ganked up by a previous owner, so i replaced that as well with one from my donor car. It was a really clean relatively rust free crossmember, i did reweld the mounts, and brush reprimer it on the inside with thick coats of epoxy primer after getting it sand blasted on the inside.
I would size the bar to the engine combination you want to run. I believe.slant sixes with A/C use 318 v8 bars but im not too sure on that. I used to do big block B body stuff only. Then life got in the way. Wife, kids, house, job, etc 20 years go byand my beloved B bodys are now made of unobtanium. This is why i got my 67 notch. Still somewhat affordable. But since its smaller in the engine bay, im going to build a hot high revving 318, 4 speed trans, and 8.75 rear. I want a well balanced car thats fun to drive and can accelerate, brake and handle like my 07 mustang GT. And i am looking at bang for the buck. Small blocks fit better and are relatively cheap to hop up these days compared to B/RB iron.
Check out article pinned to engine quests website about their all new magnum head castings that phr magazind used on an old school 318 rebuild. 402 hp at 6,200 rpm and i think 375 foot pounds of torque. 9.8 to 1 compression. So its pump gas friendly. Your notch is only 2,800 pounds with a smallblock. A 400 hp small block should move it rather well
Build what suits your tastes. But id go with a hopped up small block. If its already in your car use whatcha got, save yourself some headaches. You know it fits, hop it up
Its all in what you are using the car for.
Matt
