tarvin890
tarvin890
has anyone found a small disc/drum master cylinder replacement for a body dart with BB and fenderwell headers?:banghead:
I used the offset adapter from Mancini's as well as a Wilwood master also bought from Mancini's. Only problem was modifying the brake light switch bracket to put the pushrod on the other side of the pedal assembly. No problems now.
Kenny B
Kenny do you have a pic of what you had to modify to get the pushrod to work on the other side? thanks Mopar65
The doctor diff master cylinders rule. I recommend!
Don't see the big problem, here is mine and I have no problem with the valve cover or header bolts. It is tight but with the right tools not that big of a deal.
I have Indy 440-1 heads on my 69 440 dart. The 2" hookers were up against the master cylinder among other things. I simply lowered the engine in the chassis using 1/2" spacers on the k frame. Took about an hour and really helped a lot.
