I've been searching for some parts, or ideally, the whole secondary air injection system for 225ci slant six. Does any one have one for sell and/or could put me on the right track to get one? I plan to use it on a '75 Duster, in order to make it a daily driver I need to pass Arizona emissions. Thanks!
Exactly how much of the system is missing, and do You even know? Here in PA, motor vehicles registered in a non-test area
have to pass a visual inspection of the emissions equipment, no matter what the year & model to pass State Safety Inspection. But if the vehicle is registered in a test
required area, and has less than 5000 miles one full year after the previous insp., We don't look at it at all and issue an IM sticker with an exempt insert!
Luckily, they have started bumping the years up for not required status in test reqd. zones. If the vehicle is registered as an antique, no IM or safety insp. is reqd. Are You saying You have to retrofit an air pump? What IM testing
is Your Duster going to be subjected to? I'll be honest, I'm ignit when it comes
to when the EPA regs hit the A bodies full tilt. A lot of smog air pumps were
universal in nature, with mostly changes in adapters, valves, and pulleys. A
boneyard donor is the 1st step I'd take, check the parts cars forum here, many
of those era cars are stripped for mechanicals..................
