so what do I have to do to install this Comp 486/279 cam in my 1979 360 engine. It seems like I have to do a lot according to the spec sheet.
Recommended Components
Component
Part Number
Complete K-Kit K20-600-4
Cam & Lifter Kit CL-Kit CL20-600-4 [7]
Lifter Kit 822-16 / 867-16 [37]
Timing Set 2103 / 3103
Rocker Arms 1322-16 [23]
Push Rods 7958-16
Valve Springs 995-16 [2] / 26995 [2]
Steel Retainers 740-16 / 795-16
Valve Locks 626-16 [24]
Valve Seals 505-16 [2]
Camshaft Break-In Lube 159
Installation Notes (These notes apply to the above recommended components with the trailing installation note numbers)
Note
Description
2 [2] Requires machining on cylinder heads.
7 [7] Stock springs cannot be used.
23 [23] Includes special shafts & spacers.
24 [24] Special 10º 4 Groove Lock. Single Groove use part #612-16.
37 [37] Adjustable valve train required.
Contact us via email
The springs isn't going to be a problem as they will be new to match the cam. I plan on having the 340 x heads done and installed on the engine. It looks like according to this spec sheet that I have to have adjustable rockers. Will I be able to put this cam in my stock 360 engine along with the set of 340 x heads and go. someone tell me what I am about to get into here as I have no clue. Thanks,Bill
Component
Part Number
Push Rods 7958-16
Note
Description
