Solid Cam For A 360
mikesduster
Winter Haven,Fla.
360, .040, Balanced Crank/rods, 11:1, Ported J Heads, 1 3/4"-3" Exhaust, Single Plain, 750 With A Proform Body.
727, 8" 4200 And 4:56's
Pick A Cam For Me.
Mike is there a cam in it now ? I would look for something in the high 240s to 250s range. Maybe the biggest Xtreame energy solid from Comp or a HV5056 from Hughes, wich is actually a engle cam. They could grin it for you also, it would be a 4403/4404
You are going to have to be careful that you have enough spring height to accomodate the extra lift. If you just want to try an off the shelf grind I'd suggest Mopar's .590 cam. It performs well and will get you in the game at a reasonable cost to see if you want to play at that level.
My Hughes HTL7680AS .630/.630 with 1.6 rockers (.672) was about 3 tenths faster than the .590 (.629) in my car. However fitting that much cam in there is a chore. The .590 was much easier.
Also of note I couldn't use their recommended valve spring as they would float the valves at about 7000 RPM. I had to use a Crane Spring with 150# on the seat and 440# over the nose. You most definetly want to break the cam in with just the outer spring installed.
I'm running a Sig Erson cam 302* 312* .530/.550 lift 108* and its a midrange monster, lopey as hell but very streetable Also checking out a custom Racer Brown grind with slightly less duration dual pattern cam
