Hey all
Has anyone used solid lifters in a magnum block? I think the lifters I am using are designed for the LA engine where it oils the rockers through the shaft. The magnum only oils through the pushrod. Below is a photo of my hydraulic lifter that supplied plenty of oil. You can see the skirt between the oil band and oil hole to allow more oil.
I ran the solid lifters in my 360 magnum and there is next to no oil getting through the pushrods to the rockers. Hughes engines said i need to cut this slot for the magnum engine use but Hughes lifters were discontinued and he couldn't help me. Now I am thinking I need to pull the lifters out and slot them as Hughes suggested. Has anyone done this? I know too much oil is bad so I want to be careful how much I take out.
cheers Maca
here is a pic of the lifters next to each other and below that is a video of it running to show lack of oil
[ame="http://i1081.photobucket.com/albums/j351/maca110/VIDEO0055.mp4"]
[/ame]
cheers Maca
