Sombody explain what this IS?
67Dart273
Idaho
I always thought a late model AMC trans built to fit an AMC WAS a 904/727:
http://www.carcraft.com/techfaq/116_0701_tci_transmission/viewall.html
This line:
" You can also buy a housing adapter and mate this transmission to Ford, Chevy, or Chrysler engines."
Quote from the page:
it is a Chrysler transmission, and yes, you can bolt a version of the 904 TorqueFlite up to your small-block A-Body Mopar. The 904 we are talking about has the AMC-patterned housing that first appeared in 1972 and was called the Torque Command, a name patterned after the original Borg-Warner Shift Command that AMC used before 1972. So why do you care? Using the closely related AMC 727 Torque Command housing, Chrysler 904 internals, and a Powerglide tailshaft, you have a transmission that is as light as a Powerglide and has an extra gear. ProFlite builder Marv Ripes from A-1 Automatic Transmissions claimed this hybrid is being used in Super Stock, Modified, and Comp Eliminator cars making over 1,300 hp running 9.0 at 190 mph. You can also buy a housing adapter and mate this transmission to Ford, Chevy, or Chrysler engines.
Obviously, the holy grail combination is a built AMC 727, but since we are making 480 hp instead of 1,300, the slightly modified 904 is perfect for a lightweight car. The AMC 904 weighs 115 pounds, whereas the 727 weighs in at 135-140 pounds, and to keep it inexpensive, the TCI 904 costs around $1,000 compared with the ProFlite that will cost you at least twice that much. The AMC transmissions also have the preferred bellhousing for non-Chrysler or AMC conversions with slimmer dimensions, a lower inspection cover for easy torque-converter access, and a swap-friendly bolt pattern. The final highlight is the First-gear ratio of 2.74 instead of the standard 2.45 you get with the TorqueFlite."
http://www.carcraft.com/techfaq/116_0701_tci_transmission/viewall.html#ixzz1h83rLbTd
AMC had all brands of parts incorporated in their cars.
You must work for Microsoft. "While your answer is technically correct, it really isn't very helpful."
(On a serious note, I used to sell car parts. I DO know this. I've BEEN under the hood of many Jeeps and AMCs over the years.)
In a way, you are correct, but the AMC bolt pattern and actual size of the trans is slightly different than a standard MoPar unit. The internals from what I understand, are the same.
Which is why, I don't understand this magazine article, or maybe they don't know WTF
It's the easiest TF to put on a non-mopar. It's also the son of an unwed mother.
LOL @ SR71
67 I think it was just a interesting read on the largely unknown but yet small difference's in the tranny's. Like a "Hey, check this sh%&* out, look what we can do!" article.
I don't know all the specifics, but my cousin has a 78 AMC Jeep Grand Wagoneer with a turbo 400. It is the original drivetrain.
There just using an adapter plate to hook up the motor they want to that trans. They do it all the time with sand cars and adapter plates are used to hook up transaxles to all kinds of different motors.
AMC used the TF727 and TF904 from the early 70's in passenger cars. The FSJ's (Full Size Jeep) used the TH400 from 1966 through 1978 and switched to TF727 in 1979 and used this until the end of production in 1991. International Harvester also used the 727/904.
Seems like that shoe fit your foot with your post too.
I could have written a full article about some of the parts AMC used that were manufactured by other companies but I failed to see where it would add benificial information to the thread.
Speaking of auto manufacturers using proven parts from larger car companies..
Ferrari 400s used Turbo 400s for the automatic cars. A lot of the owners have now swapped in 700R4s...bolt-in.
Rolls used GM trannys, alternators and A/C systems on their cars in the 70s.
...about the only thing that did not break.
AMC used Motorcraft carbs and electrical systems back in the day.
OK smart guy if you knew the answer to the question, WHY COULD YOU not just simply answer it? The question I posted is NOT what every single part AMC used, it is ABOUT this magazine article, which on one hand seems to indicate that they are talking about an AMC case 904/ 727, but yet the mention that you can "use an adapter to mount it to a Mopar."
So..........back to the original question............
For the ultimate in race 727 technology, A-1 offers its ProFlite transmissions for use in NHRA's Comp Eliminator and Super Stock Modified cars, regardless of the brand of transmission the car originally came with. ProFlites are designed to fit wherever a Powerglide once resided. Based on smaller AMC 727 casings (which are narrower in the bellhousing region by 1.5 inches) and featuring light-weight 904-based internal components, these transmissions are so efficient they require only 125 to 150 psi of line pressure to function compared to the 225 psi required in the race 'Glides. The lower the pressure, the less power is wasted turning the pump. A-1 ProFlites are available with 25 different gear-ratio combinations, are available with a billet aluminum adapter to fit Chevrolet engines that allow the use of Powerglide torque converters, and are able to withstand up to 1,300 hp.
Read more: http://www.carcraft.com/newlook/crc_act/116_0302_trans/viewall.html#ixzz1hDkRNMV0
Bring your Visa..cause you are going to need it...........
