- Joined
- Mar 6, 2008
- Messages
- 1,132
- Reaction score
- 807
We have threads pop up from time to time where somebody is wondering if they should switch from carbs to EFI. I worked at DIYAutoTune in technical support for 14 years, and some EFI conversions have turned out much better than others. I'd like to share some tips to make sure that you can make an informed decision. I'll start with a couple of big truisms of EFI conversion.
1. There are a lot of "self-tuning" EFI systems on the market, but nobody's got a self-troubleshooting system. When something goes wrong, you will need to make sure you have the right resources to solve the problem - your own skills, a shop or buddy that knows EFI, the seller's support team, etc.
2. Self-tuning systems generally only tune the main fuel table and maybe a few other fuel tables. There's often still a bit of manual tuning. And nobody has a workable way to tune the spark table. A good spark table is both the key to good power and good fuel mileage. To get the most out of EFI, you will want to dyno tune the spark table.
3. Put some thought into the fuel delivery, but don't overthink it. Just adding a high pressure pump, regulator, and return will do OK on a street car except you may have problems with it not picking up fuel below 1/4 of a tank when cornering. There are a number of ways to avoid fuel slosh issues, some of which are pretty cheap if you have the right equipment, such as welding a sump to the tank. You can spend hundreds on a custom baffled tank or a complicated surge tank system with two pumps, but you don't have to.
4. A throttle body injection system is about halfway between a carburetor with an OK-but-basic tune and multiport EFI in terms of what you will see in terms of drivability. Sometimes that may be what you're OK with; other times you will want to go big or go home. Or rather, go multiport or stay carbed.
5. "Self tuning" generally works best on mild engines and needs a fair amount of distance between the O2 sensor and the exhaust outlet. If you have an aggressive cam or some sort of really short exhaust that has a foot between the O2 sensor and outlet, expect to tune the idle and low RPM by hand.
