If you add the factory sway 71 bar again they will hit it, that is why everyone mounts the calipers to the rear on 72 back A-bodies.
Had to do this to my 72' Duster just for this reason....has factory front Swaybar!
My 66 B body sway bar clears, but it looks like your A body sway bar mounts farther out on the LCA.
Good info to have.
NOTE: PLEASE DO NOT USE ANY OTHER BODY STYLE CALIPERS: ROTORS: PROPORATING VALVE: OR BEARINGS, OTHER THAN A-BODY FACTORY PARTS
***** MUST READ !!!!!!!! DO NOT USE VALORE' OR ASPEN DISC BRAKE PARTS, THIS WILL CAUSE YOUR CAR TO HAVE WHAT IS CALLED "BUMP STEER" :glasses7:
slider calipers
BS...
I use ONLY FMJ spindles as do many others.
http://www.bigblockdart.com/techpages/spindles.shtml
Mine is a 73-6 k frame with a body brakes and sway bar
????? seriously? do you still believe in that outdated article? just asking is all I'm not trying to start a war here, but I think that's one article that has been busted.
