Spark Plug Recommendation
CL3406
BC
Curious what some of you are using for spark plug make & part number? Application is 340 6 pack, 4 spd, 3:73 gears at rear, cross over plugged, 195 stat, stock grind cam. What else do you need to know? Thanks.
I ran autolite 63, They are copper core and hold up well. My set up was almost the same but bigger cam & 3:91
i'm running autolite 64 in the dart.. pretty much run a 63,64,65 with stock heads. i'd rather have the NGK but the place i was at didn't have them so autolite it was.
