Just stock X heads, 69 Block 10.5 to 1.What heads are you running?
Thanks everyone for your input!
Did you use the NGK 2635 like the other A body members mentioned? ThanksJust curious, the eddy heads wont accept the factory size hex on the plugs.
Ive had good luck with ngk
Yes I am aware of that. Thanks for the info.stock heads can use any 3/4" reach gasketed plug with a 5/8" or 3/4" hex
