Spark plug tubes.
Nope. I removed them from my magnum powered truck many years ago. Never had an issue. I removed them from the 5.9 in my dart also.
Thanks folks, I figured that was probably the case, but one never knows what esoteric engineering decision drove the implementation of those things. They just look kind of silly to me.
Not if you use modern silicone plug wires. Can also slip a woven fiberglass heat shield over the plugs. I recall GM's LS engines use that. Come in flashy colors on ebay.
any value to them with headers, to protect the wires???
I had manifolds and headers on my truck. Never had an issue. My dart has Doug's headers and a 5.9, also no issues.
I recently bought a '98 viper GTS. It has the same spark plug tubes that magnums had. It shares quite a few parts from the magnum engines ive learned! I removed the tubes when I changed plugs and wires. No issues there either.
Just squeeze them by hand and wiggle and pull! Pliers make it super easy, but can bend them some.
