Spark plugs covered in oil - how screwed am I?
SlantedMark4
'74 Valiant 225 /6
Switzerland
It all started like a month ago when my Valiant (225 Slant Six, 1974 model year), misfired badly. It stalled 4 times in less than a mile of driving. I was lucky to be near home.
I've started the car like a week later again without any issues but replaced the ballast resistor because it was a bit crumbly. I've barely touched the car since but yesterday I thought I should check the spark plugs to be sure these are not the cause for the misfire and holy ****, I've never seen spark plugs to be this oily. I have removed all the spark plugs and spark plug tubes, cleaned everything (the spark plug tube seals are rock hard btw) and scratched the carbon off the electrode, just the normal work you do... I then let it run for like 5 minutes, let it cool down and the spark plugs are a little oily already again.
It has some excessive oil consumption but I thought it was a loose connection on the oil cooler to cause that but now I think it is burning the oil...
There are no weird sounds, only the famous lifter tick. No weird knocking or anything else and the idle is smooth. The valve cover is a bit wet on top but not much. Throttle response is fine and I don't hear weird noises when I rev the engine. There is no smoke coming from the exhaust. I can't say if there is a power loss because I've driven my Valiant for just around 1400 miles.
I think compression testing is the first thing to do, right? It looks like the piston rings or valve seats / valve stem seals are bad.
I've read it is possible for a valve gasket to leak into the spark plugs and causes misfires but in a Slant Six? The spark plugs are at the side of the block, not in the valve cover? This is btw the first time I work on a slant...
The spark plugs from cylinder 4 to 6 were the worst. The one on the green towel is from cylinder 6 (closest to the firewall/bulkhead).
How Much oil do you use per 1000 miles?
Blue smoke on startup?
Pull valve cover and look at your valve seals. V8’s have neoprene umbrellas, not sure about/6’s. They get old they harden and bust up to pieces from heat cycling.
Compression test will tell you if you have a real problem, followed by a leak down test will give you a good idea what the problem is.
no worries mate, just throw some two stroke plugs in it.
some B7ES ought to fix her right up, have it humming like a vespa in no time!
In addition to what has been said about the plug tubes, etc, make certain that something hasn't happened to "wash" the rings. Maybe the carb needle seat stuck and flooded it bad, maybe the FUEL PUMP is leaking gas into the pan.
I would get good plugs in it, make sure it seems to be running OK, go for a long enough drive and at speed to get it fully warmed up and then monitor the plugs and oil level
Install new plugs, remove crush rings if they have them on heads with tubes. NGK3459/ZFR5N is a good plug for these. Any seals that are hard must be replaced. They are no longer seals but leakers.
I hear tht a good source for info on these is @slantsixdan
Prob valve seals to look at
As I said, I drove it like 1400 miles, poured in like a liter of oil already and now the oil level is below "low" already.
No, there is no smoke at all. Maybe a tiny cloud the second after startup but nothing special.
I go try what the other guys said and see if it helped. I really really hope the piston rings are fine ...
Thank you very much for your informations! I'm gonna see if i can get these plugs asap. But a question: Why do I have to remove the rings?
When you have tubes, the tube acts as the plug seal.
If you don't remove the crush sleeve, it will leak because it can't seal to the aluminum tube, only a steel/iron seat.
Like double gasketing an oil filter, a big leak.
If your oil was burning you would have a lot od blue smoke, fuel will smoke black. No smoke ? no oil/fuel burning.
But where would go the oil instead? I'ts not a small amount that simply disappears...
Dunno about you guys, but a quart of oil loss in 1400 miles isn't all that bad. I burn more than that in my worn out slant, and I'm not driving a fog machine.
Agreed, a quart/1,000-1,500 miles isn't that bad for an original high-mileage engine from the 1970s.
The firing end of the plug looks fine. The outside of the plug is oily because you need to cut the washers off the plugs. The drool tubes act as the washers on those heads. When you leave the washers on, they can leak. Not always, but they can. Also, Chrysler came out with a service bulletin I believe in 1963 saying you should not use the washers with the drool tubes, because it did not allow the plug to enter far enough into the chamber with the washer on. It probably wouldn't hurt to replace the droop tube seals, too.
I apologize for my late response. I've spent some time in England.
I did some reading and felt stupid because I have had an oil consuming problem earlier with my daily and we've replaced the PCV valve then... I mean a malfuntioning PCV valve can suck oil instead of air, so I've removed the PCV and EGR valves yesterday. The PCV valve and the hose are oily all the way to the carburetor. The hose itself decided to be a biscuit when it got removed. The EGR however is pretty much clogged. I think these two issues might be a part of the oil consumption thing. Both valves are the original parts as they look...
In that case I think replacing the "Valve Cover Breather" (or whatever it's called) might not be a bad idea. Does someone here know the OEM part number? ('74 225 /6)
How do I clean the intake manifold form all that stuff without removing it? Brake cleaner and compressed air? Vacuuming?
PCV Valve 3671076 -> Replacement parts: SMP V165 / WVE 6P1063
PCV Valve grommet -> Replacement part: Dorman 42064
EGR Valve 3830178 ->Replacement parts: SMPG EGV122 / WVE 4F1184
Is that like wanting to take a bath without taking your clothes off ?
Seriously, you really need to take it apart to get to all of the areas to do a thourough job.
That stuff really gets hard and is not easy to clean. Brushes, picks, solvents... no easy solution.
Hard to tell from the pictures, granted the plugs are oily but the electrode looks to be covered with soot.
Agreed.
Looks like a combination of drool tubes leaking into the plug and an overly rich mixture.
Also kind of leans toward one thinking there are some other exterior leaks as well.
Edit: The valve cover breather is completely clogged aswell with oil.
