BillGrissom
Somewhat. I installed a Mopar e-distributor and an HEI module in my 64 slant, but haven't finished wiring it up (other tasks, and home jobs before cars). I know I have a 50:50 chance of getting it right the first time. I did test sparking by spinning the distributor. Now that I think of it, I should have shone a timing light (triggered off coil HV wire) at the reluctor teeth while spinning the distributor and see where it is triggering to take the guesswork out. I'll do that before I complete the wiring.now that's sounds like experience talking............Artie
My "spin test" also showed that I need to twist the pickup wires since the module sometimes "self excited", i.e. positive feedback. That is easy to get in temp wiring with alligator jumpers strung about. One final note, I also found that some pickups have the wrong double-bullet connector. I bought 2 new ones off rockauto at the same time, and one made erratic connections since the male terminal was too short. The manufacturer appeared to have used a standard applicance connector, whereas the Mopar one is a bit different. Check yours carefully.
