Speed signal
mcfly68
New Member
Belleville, Ont
What are people doing for a vehicle speed signal with a '10 ecm ( normally handled through the abs module and sent over the can to the ecm, since this is a resto mod...no abs..and not needed for speedometer...needed so the ecm knows when the vehicle is stopped or moving)...the setup is a 2010 5.7 challenger motor, 2010 ram ecm ( for controlling the 6.4 srv intake), 6.4 intake and cam, headers, a500 (44rh from 1 ton van) trans, ford 8.8 with 3:73...so lots of speed sensor positions available ( diff and in the trans) but cant find anyplace to wire the input into the ecm , unless the signal can be wired into the output speed signal on c4 connector pin 32 with the rest of the trans functions disabled
