Daniel Dugas
Has anyone ever ran the speedmaster assembled hydraulic flat aluminum heads? If so how did they work and are there any problems I need to know before I purchase? Thanks
If that's the case I wouldn't waist my time or money on the Speedmaster.Okay thank you. They would be going on a 72 demon bracket car
The Trick Flow 190 is far superior OOTB.
buy once, buy
buy
In which ways are Trick flow better? more reliable or just straight up better power and quality?If that's the case I wouldn't waist my time or money on the Speedmaster.
buy once, buy
I agree, that's how I found out about the quality of a trick flow head (still needed valve spring heights adjusted) and the problems with others.There are ZERO aftermarket heads I would buy and install out of the box. NONE. I would take anything to a competent machine shop and have them heavily inspected and or corrected if need be and the need is usually there. That's a lot of money to just throw away without checking. @318willrun has a video and story about just this very thing. Maybe he will post a link.
Did you see @318willrun's video? There was so much trash and what looked like left over grinding material and debris in the ports and bowls it would have destroyed the engine completely had he slapped them and started it. It was horrendous.I agree, that's how I found out about the quality of a trick flow head (still needed valve spring heights adjusted) and the problems with others.
I did, that's just another reason I take them apart, I like to know what I have and there isn't one set that I've seen that had the spring heights right. That said my trick flows have been the nicest heads yet but even then I had one with a bad head surface, summit immediately sent out a new one with a call tag for the old, great customer service.Did you see @318willrun's video? There was so much trash and what looked like left over grinding material and debris in the ports and bowls it would have destroyed the engine completely had he slapped them and started it. It was horrendous.
Wasn't that just ridiculous? Talk about zero quality control. But that's the world we live in.I did, that's just another reason I take them apart, I like to know what I have and there isn't one set that I've seen that had the spring heights right. That said my trick flows have been the nicest heads yet but even then I had one with a bad head surface, summit immediately sent out a new one with a call tag for the old, great customer service.
Agreed, chinese head castings better than american, intake bolt holes that are way off from the ports, hell I can't even get the same quality of food at the local restaurant twice but they have the "gratuity" already added in to my bill.Wasn't that just ridiculous? Talk about zero quality control. But that's the world we live in.
Sickening, ain't it?Agreed, chinese head castings better than american, intake bolts that are way off from the ports, hell I can't even get the same quality of food at the local restaurant twice but they have the "gratuity" already added in to my bill.
Of course you knew he would always makin it about him. lolLMAO @ AJ - Good mention!
...... righty OSince this is the racer's Forum, I won't mention that with alloy heads, you can run the Dcr up into the NINES.
I am a steeter, and have run up to 9.23Dcr (195psi) always on 87E10, always without detonation.
Starting with 65cc chambers, may be an issue.
Jus saying
Jus saying
Since this is the racer's Forum,...... righty O
Pingity, ping, pingity , ping, pow.
It wasn't about me until some of you guys made it so. I was just trying to help.Of course you knew he would Always makin it about him. lol
If this is true, then I am happy to be wrong.Damn. Still preaching nonsense about aluminum heads and compression ratio. You are WRONG dude.
Boy you sure are humble. .....NOTSince this is the racer's Forum,
I didn't want to say more;
but somebody not you fishmens, poked the bear, making it personal; so
Firstly;
I Ran it like that (post 19) for an entire summer, and, with a regularly scheduled teardown every winter for inspection; there was no sign of detonation. It was the strongest bottom end I ever had and my favorite combo.
On the next combo, a one-size bigger cam, the pressure came down a tad. I really missed that. So much so that I swapped the 2.66 low out for a 3.09. This allowed me to retard the cam, and I picked up a good amount of top end. Car went 93 in the Eighth @930ft and 3467 pounds, me in it. with 3.55s no less.
But you know;
according to some
it can't be done.
Like said; I'm a streeter with a clutch; bottom-end is everything.
With the GVod used as a splitter, my new combination of gearing, gets me; Four ratios in the Eighth, namely;
3.09-2.41-1.92-1.50 ; which in Roadgears with 3.55s is
10.97-8.86-6.82-5.32 ;
and 93mph is 6170 ;
and it takes off like it had 4.10s
First-over gets me 50@5100/60@6400, Second is 60@5100/75@6400; Power Peak is ~5100
This combination was a culmination of five years of experimentation which ended in 2004/05. After that, it was settled and I just drove the crap out of it. Both the car and I are semi-retired now. Every once in a while I take it out for a spin,
just cuz..........
Secondly:
But you guys are the guru's, and love to put me down.
I'll tell you a couple of things tho;
1) I'll never go back to low-pressure, and
2) I'll never go back to iron heads, and
3) I'll never go back to low-temp stats
4) regularly-scheduled inspection teardowns
are cheap compared to dynomited engines.
5) a lil too much ring gap is, by far, better than tearing off lands. For a Street-car, now; If when you shut your engine off, ten minutes later, it won't crank cuz the pistons ain't moving; do yourself a favor, don't bandaid her up with cooling system mods; just do what needs to be done. She needs to come apart, and get fixed. Loosen up the skirts and open up the gaps.
6) If there ever is a next cam, it will be a solid lifter.
and Thirdly
I could be wrong about a lot of things; like, the shape of the Earth, the Second Coming, The THIRD Resurrection, the Four Corners of the Earth, and the Seventh-Day Sabbath...........
Fourthly;
Can you run a streeter at 195psi with iron heads?
Last I checked, not NA on 87E10.
With alloys, I've been right around 180 now, for going on 9 years. yes still and always on 87E10. And BTW, until October 2022, it was still on the original Champion copper plugs installed in 1999. In 2004 when I ran that Eighth, the plugs were already over four years old, and likely had close to 40,000 miles on 'em.
Once again,
jus saying.
