[SOLD] Speedmaster SB Dual Springs
12many
SC
Speedmaster dual valve springs removed from new Speedmaster small block aluminum heads (for hydraulic flat tappet cams)
Brand new.
Specs For Springs As Suppled by Speedmaster:
1.45” Outer OD
1.060” Coil Bind
.834” Inner ID
145lbs @ 1.900” installed height
Closed pressure= 145lbs
Open pressure= 360lbs
These are $50 shipped. PayPal only, in full. No payment plans, down payments, holds, life stories etc.
Brand new.
1.45” Outer OD
1.060” Coil Bind
.834” Inner ID
are those measured spring pressures? - and what was the open pressure height?
Thx
Never bothered checking how they were set up from SM. I removed them and installed something else. The only specs I know of are what I posted from SM.
I have them checked on my heads and the specs were very close if not spot on. I'd have to look...
