Speedometer Lube
Speedometer cables are not supposed to have any type of grease. The correct type lube is dry graphite powder.
Any type of grease will gum up and cause problems later on down the road, because it will overheat eventually. Speedometers cables rotate very fast and will overheat grease and break it down over time. Graphite powder will not.
Agree. What I used on my old 71 years ago. Also used WD-40 to get it down into the cable housing. Used the graphite as what is used for locks. Getting to the cable housing is the biggest part of the task.
From the FSM:
SPEEDOMETER CABLE
To service a noisy speedometer cable, disconnect
housing at speedometer head. Remove shaft and clean
it thoroughly. Apply a very thin film of speedometer
cable lubricant on the shaft. Such a lubricant is available
under Part Number 1243632, Speedometer Cable
Lubricant. Wipe excess lubricant from the top one foot of cable and ferrule.
FYI the lubricant specified is Lubriplate ( White Litium Grease)
So I put the lube where it goes into the speedo housing and I also used it on all the little gears and such.
Been about 8 years now. No issues, and I had some real problems. The needle would bounce and the gears would tick. There was grease on the gears from the factory but it was all dried out.
I drive my car what I think is a lot. I have put about 48 thousand on it over 30 years. That's also including 10 deployments which equals about 7 years of being gone. So figure 23 years total. Minimal in winter, about 2-3 thousand miles a year 600 round trip to Carlisle every year that I could go.
Yeah I'm anal on numbers.
Rick
Rick
I cleaned all the componenets in mine, and used weed eater cable lubricant. no worn parts to be seen, and it still bounces about 5 mph.
I know this is an old thread but I had to but in there is one thing I know it's cables (motorcycle mech) Go to either motorcycle shop or your local parts house MAY have it but there are all kinds and brands of CABLE LUBE. Take the cable out of housing and clean it and flush housing blow out with air and spray lube all down the insert and spin with drill to check for cable spurs.
FWIW, I use speedometer cable lubricant on the cable, white lithium grease for the speedometer itself.
And I wipe off the speedo cable lubricant from the top 2-3 inches of the cable. It's really not meant to lubricate the speedometer itself.
Can't remember where I read all that, but that's the way I've fixed several noisy speedometers.
