Speedometer problem '69 dart
ir3333
ontario,canada
o.k. ...fuel gauge working correctly now (replaced float on sender)
....charging system working o.k. (replaced voltage regulator)
...now speedometer stops at 60 mph,otherwise it works fine and is accurate
your thoughts?
Tx in advance
...problem found.
dis assembled everything and the speedometer needle hits an injection moulding stud
on my new PG Classics gauge bezel.
should operate properly now that i have snipped it off.
...hope this helps someone else.
I'm not sure I'm even going to bother with mine. I currently have some 3 or 4 (lost count LOL) used GPS units, they work great for speedos LOL
...problem found.
Thanks for the info................same problem here and I put another speedometer cluster in with the same 55-60 mph stopping point. Those guys need to correct that on their product.
