Spitfire collectors
cmac64dart
mays landing nj
What collectors /exhaust bend combos did you guys use to navigate around the torsion bar on your earlies with spitfires. I will be running a 4 speed with hydraulic clutch. Any pics would be appreciated . Thanks, Chris
Driver side
We'll, I appreciate your help. The picture gives me a starting point. How did your car sound with the spitfires on it?
You're welcome. I think it sounds amazing. More impressive is the power versus the early manifolds- no comparison at all. They don't burn plug wires and weigh less. I suggest getting smaller header bolts because the clearance is tight
Were there ever actual destructions for these, or are you just sposed to "do what you can?"
I wasn't the original purchaser new. I'm not sure if they ever came with instructions but I never had them.They were ceramic coated before I got them.
I have to pull the steering column to remove the driver side header. Not a big deal.
Shortening the column isn't required but it makes working in there nicer.
