Splash Shield?
danthedewman1
Ava, Missouri
Hi...On my 72 Dart Ive removed the fenders. And on the splash shields?,,,I guess there called,,theres a rubber gasket where the fenders seals up against.Is that rubber gasket or seal available thru vendors ?If not ,is there a way to make your own.I want to pull mine off,and do a little rustproofing.Thanks....DAN
The only place I have seen them available and where I got a pair is Restoration Specialties. They were reasonably priced too. They also have the seals up front behind the headlight buckets.
