spool mount engine brackets
csx452
Dunmore, Pa.
I'm converting my 72 Dart from a /6 to a 360 and I'm going to use a spool mount K frame. I'm looking for the spool mount brackets for the 360.
Thanks,
Frank
Thanks for the responses. After thinking things over I've decided to go with the Schumacher mounts. A lot more money, but I'm only doing this once and want to do it right.
Frank
I'm not selling parts but the factory spool mount set-up is the way to do it right.
I've got a set of Schumacher mount brackets that have never been used. They were going on a 73 Duster but the project got cancelled.
Ken
Edison, NJ
If you have a \6 K member you will need those adapter mounts to install a V8.
Its not thats ones better than the other , the Schumacher mounts are just a $180 copy of the factory mounts.
