Spring cone style suregrip
Gator77
South Jersey
I saw the how to thread on how to rebuild these units on here. That's awesome.where would you buy the shims needed for rebuild?thanks for info.
I've had a couple that the cone had dug into the housing and once the cone bottoms out it slips. I grind the end off the cone so it has some clearance and shim the other side.
I get them at the Ford dealer. They come in a package of; chit I forget how many....... maybe 4. Sorry no PN.
I showed up at the counter,with a side gear and the old-timer reached back and when it came back, there was the right part in his palm; That's my kinda parts man.
I set the turning torque to minimum 100 ftlbs with the correct oil pre-installed. Maximum 120 or it will be a spool on the street.
