The Wankle rotary engine eliminates a lot of parts. Ive been thinking of combining 6 or 8 Wankles in a circular arrangement at the rear end. Why not?
Been done a LONG time ago with solenoid. I'm honestly surprised it hasn't made a comeback with all the new techOne thing that has been in my mind for years.........and surely it will happen some day.........is a CAMLESS valve system. Just imagine, some sort of electric, electronically controlled valves, which you can vary with the ECU, you have a DD, gas mileage king, and the wildest "cam" you can imagine, all in one box.
also been done quite some time ago. Look at two strokes and there are some engines using it now, in Europe as I understand it.Rotary valve, picture a shaft with hole through it spininng. Just have to be able to seal the ends of the shaft. Damn physics!!!!
Pneumatically operated valvetrain......F1 for years,.......why do You think the FIA had to impose a 20,000rpm limit on the engines....................One thing that has been in my mind for years.........and surely it will happen some day.........is a CAMLESS valve system. Just imagine, some sort of electric, electronically controlled valves, which you can vary with the ECU, you have a DD, gas mileage king, and the wildest "cam" you can imagine, all in one box.
Lots of old 2-stroke Jap bikes runnin' around with just that, I have a 175cc Yamaha F7 circa early '70's & the carb horn mounts right on the rotary-valve housing on theRotary valve, picture a shaft with hole through it spininng. Just have to be able to seal the ends of the shaft. Damn physics!!!!
Thee are plenty engines out there that are not interference enginesI think the failure rate of those electric solenoids would be too high. And if one hangs open for a split second, goodbye piston & valve(s)! If a cam fails, it usually wears out over some time. You might notice the engine not running right long before catastrophic failure takes place. With electronics, usually they just stop working, or short out suddenly, with no warning.
Also like marriage, you don't know what the cost will be until you get into it.Because complication in life will make your hair fall out. Sort of like marriage. Oh well...I'm going to take it on the chin for that one.
Mazda ran a three rotor engine, ran it in a prototype sports racer at Le Mans in 1991 and won, only to be banned afterwards. Bad *** car.The Wankle rotary engine eliminates a lot of parts. Ive been thinking of combining 6 or 8 Wankles in a circular arrangement at the rear end. Why not?
