SSI camshaft PN 10322
DRVDuster
Active Member
Mexico
Does anyone know the specs of this cam?, a guy is selling me one in good price, but it does not advertise any specs.
It will go in a 318
No i do not, but IIRC, you can look this part number up if you have a old PAW catalog.
Check out old Hot Rod,Car Craft magazines,circa 84-85,to 98-99. P.A.W.,used to run 3 to 4 page ads,with SSI cam numbers and specs listed.
Yeah, Super Stock Industries! Those cams were 49 bucks, cheaper than regrinds! Break 'em in good and they are fine. In your case, just mic the lobes for sure.
I have a PAW 2005 catalog that lists a SSI cam #10323 as being for a big block Mopar engine. I don't see the number listed that is on this post. My catalog may be too new.
Ok, got it 276/286 duration and .441 lift.
Will this work fine with stock compression?
I was searching around and found this Summit grind that has those type numbers.......
http://www.summitracing.com/parts/sum-6901/overview/make/plymouth
That's about as big as i'd go on a stock compression 318.....The 218@.050 intake duration will make it a little soft under about 2500 rpm's, but if you have any stall over 2200/2500 or a rear gear 3.23 or more, it should work ok in my opinion.......Just remember to run a aggresive timing curve, 14-18* initial and a total around 36* as that will help the low end alot.
Thanks for the replies
My car is 4 gear manual transmission with 3.07 gears, the engine heads are at the shop now, they will be milled a little bit, like 10 thou, I know is too little, but maybe it will help
I think you'll be happy with it.....Also knowing the heads are nice and flat you could probably use a thin gasket (maybe in the .020/.029) range and give you a little extra squeeze.
