stalling in gear
First, find out where your idle mixture screws are presently set. Count how many turns it takes to bottom the screws, and bottom the screws gently. You'll probably find that it will take 1 1/2 turns or so on each screw to bottom them. Back them out to where they were when you started.
Hook up a vacuum gauge to an intake manifold vacuum source, watch the needle and take note of what your reading is. Turn the screws in 1/4 of a turn at a time and see if your vacuum reading increases. If it does, turn them in another quarter turn. If not, back them out a quarter turn and see if vacuum increases. If it does, back them out another 1/4 turn, etc. I think you get the idea. You'll also notice that rpms will increase and you may have too adjust your idle speed again. If you do have to adjust your idle speed, check your idle mixture screws again and see if you can manage to get any more vacuum.
You will also notice that engine will run far smoother when this process has been completed, and may solve your inconsistent idle problem.
Let us know if this helps. BTW, vacuum gauges are cheap and can be had at any parts store.
I fixed the idle mixture and its running better now it hasnt stalled yet so i think it was the idle mixture.
10* initial timing?
Where does the timing go to when you connect the distributor to the constant manifold vacuum port?
After driving around for a little while and the rpms started to jump down then back up and it stalled.
I know this may sound far-fetched, but is the ground to your engine tight? What about your chassis ground cables/wires. Are they tight and free of paint?
When the rpms drop, is it still running on all eight or are you dropping cylinders?
i switched distributors and put my old one in and it hasnt stalled at all yet and seems to be running better.
i was about to say something about accel products myself.............
kragen race stuff.
the acel distributor wasnt working right i put in my old distributor and it runs better and hasnt stalled at all.
