canyncarvr
Hello folks:
I got a good bit of rebuff when I asked a question earlier. People wanted to know things I hadn't posted...I didn't think were at all related. I had NO intention of leaving stuff out, thought I was doing everyone a favor. I hope to do better this time.
Took my Duster to town for some clear 92 fuel. It started, ran, restarted, ran summore, stopped by the grocery store...started and ran again. Fine.
At home, sitting in the driveway idling, it quit. It's never had a problem idling for a good bit...it's not something I generally do. Tried a restart. Engine started, died when ignition released to 'run'.
Ignition box is a Standard LX-101. It's been in for a good 5-6 years. It's a 4-pin box.
I found the BY (blue wire/yellow trace...feed to ignition+ at the ignition box) broken off the back of the right hand (looking at it) ballast connector. Gee...how easy can THIS be!!??
My ballast is NOT currently in use. I have a shunt between the bottom female spades, left to right (four pin ballast). The nylon connectors are NOT plugged onto the ballast. This can NOT be a ballast resistor problem because the resistor is hooked up to nothing. Well...it IS bolted/screwed to the firewall.
I removed the female spade from the connector the BY broke off of. I opened the crimp/barrel of the old connector to make room for the BY wire, I used 320g black paper on the connector, cleaned with 99% alcohol, flux applied, wire and terminal tinned before closing the crimp, soldering the two (terminal/wire) together. I stabilized the connection with heat shrink. I was AMRIP (Avionics Module Repair) in the service. I don't always do a 100% job, but do know my way around electronics with a soldering iron.
I re-placed the female spade into the nylon connector. MY VM shows I have voltage on the BY wire at both start and run key positions. Repeat...ballast is NOT connected, shunt wire in place as its been for many moons.
Engine starts with key in 'start', dies when key is released to 'run'.
It's DTST..Doin' The Same Thing!!
I have voltage (measured with a VOM) at both the BY (blue wire/yellow trace) at the igntion box plug AND at the + side of the coil in both <start> and <run> key postions.
I do not understand the situation: Engine starts with key turned to <start>, but the engine dies when the key is released to <run>.
Hope I didn't leave out any deemed necessary information this time.
Any ideas?
Thanks.
Any ideas?
Thanks.
