friesza
The Machinist
I have a friend who is working on a transplanted 440 with a 4 speed....it has the stock bell housing but they installed an aluminum 130 tooth flywheel.
He bought an aftermarket mini starter for a 130 tooth from summit but says it is nowhere close to engaging.....is it possible that because the smaller diameter of the new flywheel that maybe an aftermarket bell housing is needed? ....this is the starter... http://www.summitracing.com/parts/cvs-1337/applications/flywheel-flexplate/130-tooth/engine-type/v8
According to ram clutches website a 130 tooth flywheel is12.25" and a 143 tooth is 13.75" O.D....
I have not seen his application just going by the info he gave me....
Thanks...
Thanks...
