jonnyboy1617
Active Member
First of all, thanks for the help with the fender question I had, it felt to late to say it there and re-open the thread.
Okay, so I am now putting bondo on the duster
I was wondering how do I get the panel back even again since I have only sanded the primer to metal in select areas. Do I go back and spray only the places where metal shows? Then block sand again? Or do I just spray the entire car with the final primer once Im ready, and block sand it even? I hope im making sense.
And also, I still see black "rings" around the bondo where the primer did not sand off. Does this mean I need more bondo around the outside of the area? Thanks.
