1974 Duster problem I have replaced the NSS, and ignition switch the starter relay but it still only starts intermittently with ignition switch. The car will start everytime at relay and just recently when the ignition switch is turned on the starter seems to be low on voltage and not engaging the drive gear if you jump the relay it works great. After replacing the ignition switch now the power to the car only works on occasion but it will still start by jumping the starter relay. The car has the wires going to the seatbelt interlock switch but none of the seatbelt wires are attached in the interior. Any help would be great! Now I am really lost on the issue!
