the pin you have to knock out is tapered, look for the "wide side"of the hole and knock out from the other.
The three i have taken apart the pin is a straight split roll pin. Plus the couple rebuild kit I picked up at the local Dodge dealer came with a stright split roll pin.
They will ome out from either direction but rust can make it a bear.
