Steering column locking mechanism removal
Suspension, Steering and Chassis
  1. T-Man700
    T-Man700 FABO Gold Member FABO Gold Member
    297
    51
    Aug 14, 2012
    Ohio
    Local Time:
    5:49 AM
    Having a problem removing the locking piece on a 72 auto column. I want to use the power steering shaft from the auto to then use on my floor shift column. The floor column just had a pin to remove. The auto must use a different tool. Any ideas would help, thanks in advance. The last photo is the floor piece for reference.
  2. Ceedawg
    Ceedawg Well-Known Member
    371
    235
    Aug 2, 2016
    Va
    Local Time:
    5:49 AM
    Same, take that collar off, pin under it. I never put it back on especially for a drag car, you can then cut the ignition off and not be afraid of locking the steering.
    • Agree Agree x 1
    • cudamark
      cudamark FABO Gold Member FABO Gold Member
      8,354
      1109
      Mar 14, 2009
      San Diego
      Local Time:
      2:49 AM
      Yup, that little stamped steel cover comes off the hub to reveal the roll pin.
    • T-Man700
      297
      51
      Aug 14, 2012
      Ohio
      Local Time:
      5:49 AM
      Awesome, that’s easy enough. Thanks
    • cudamark
      8,354
      1109
      Mar 14, 2009
      San Diego
      Local Time:
      2:49 AM
      Isn't that piece the same whether it's a column shift or floor shift?
    • SGBARRACUDA
      SGBARRACUDA ROY FABO Gold Member
      20,148
      8487
      Dec 7, 2006
      PLANT CITY FL. and PERRY GA.
      Local Time:
      5:49 AM
      That was a design flaw in the early Dusters. I had one that i blew the clutch. I reached up and turned the key off and it locked the steering wheel with the wheel turned slightly to the right. I wound up in a ditch.
      • Like Like x 1
      • T-Man700
        297
        51
        Aug 14, 2012
        Ohio
        Local Time:
        5:49 AM
        Looks like my floor shift column was taken apart before and not done very well. They even welded the two pieces of steering shaft together instead of just using plastic pins. So much for safety. Got that locking collar off already.
