Steering column to transmission
It “might” if you were using an OEM column that used a column shift. It might be able to work using either the reverse/1 or 2/3 pattern. Have you thought about swapping to a regular later column shift steering column?
I am hoping to be able to use an 80 or so tilt, column shift steering column in my 47 Dodge and fabricate the linkage to operate an A500 transmission.
Would love to see some pics of your 50 and the motor swap!
Ok sounds good. Thanks. I’m trying to keep as much as possible original. I’ll post a few pics later today. Thanks again
